horn repair and airbag light is on
My airbag light is on and my horn does not work, they both failed at the same time,
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sounds like you need to replace the clock spring Its the wire harness that keeps your wires conected as you turn the steering wheel.
https://www.youtube.com/watch?v=VxYHC6oX...
This is a brief tutorial on replacing one. Hope this helps
このアンサーは役に立ちましたか?
It's the clock spring I figured it out after i reset my dash lights three times and it illuminating my airbag light..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 19
今までの合計 7,664
