メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140回答 すべてを表示
締切られた回答
Water dispenses even when not on brew?
I previously had a problem with the machine not getting any water, but I fixed that by unclogging the tube. Now the machine continuously dispenses water while it is turned on. The machine stops brewing water if the steam button is on though. Also water leaks from in between the machine and the portafilter.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If the pump is running then either the brew button is depressed, the steam knob is not closed far enough or some wires have gotten crossed or reconnected wrong. I would start with the steam knob; with the top of the case removed it should be obvious if it's closing far enough to deactivate the pump switch; if not, you'll need to adjust the stopper to correct this behavior. Leaking from around the lip of the portafilter might indicate that your brew head gasket needs to be changed; it should be clean and slightly springy when prodded. If it's hard or has a groove worn in it then it can't provide a good seal.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 122
