メインコンテンツにスキップ
Repair guides for the Kenmore 80 Series of washing machines, manufactured by Kenmore.
122回答 すべてを表示
Why wont Kenmore 80 series washing machine go into rinse
I have a Kenmore washing machine model is a 80 series it will let me go into the wash cycle but it will not kick it out to drain the water to go into rinse what do I need to do to fix this problem
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Water Pump Belt
If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump
How it Works:
If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose
Other Causes and Conditions
How it Works:
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt
How it Works:
If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly
How it Works:
If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly
How it Works:
If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose
How it Works:
If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap
How it Works:
If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Check your lid switch. If that is working properly it could be your timer.
I removed my timer and cleaned the contacts with CRC electronic cleaner and wiped the cog wheel while hand turning to clean the debris out. It works perfectly now. It no longer gets stuck in tbe wash cycle.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Scott Allen さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 21
今までの合計 5,615
