メインコンテンツにスキップ
Model no. ML-2510, monochrome laser printer
Picks up a second sheet of paper and jams
The printer regularly picks up a second sheet of paper which causes a jam. I have fitted a new roller which doesn't help at all and cleaned everything visible. This happens both with the bottom feeder tray and the manual sheet feeder. It's getting worse, so that now it even does it on a single page job. Printer has done a total of 10k pages and 500 odd on the current cartridge.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 8
4 件のコメント
I'm having the same issue. It seems as if the printer doesn't recognize that a piece of paper has been picked up and continues to repeatedly actuate the roller mechanism. I don't know enough about this model be certain.
さんによる
I am having the same problem I guess. When it prints the printed copy is no fullly released from the printer and another sheet has been partially picked up and then everything starts and I get the alarm. I put the sheets out and open and close the top door and then it is ready to go again.
さんによる
It the pick up solenoid. It has two rubbery pads that go sticky, and it can get stuck either opened or closed. Repair is easy (remove the sticky pad and put a piece of thick tape or foam), but accessing the solenoid can be a pain. On the 2525w it's on the left side of the machine. You have to remove the left cover (which implies removing the rear and top cover first), then the motor plate.
さんによる
Thanks. I had the same issue on my Samsung 2525w and putting tape on the solenoid fixed the problem.
さんによる
コメントを追加
3件の回答
ベストアンサー
I believe this is the answer, the solenoid that engages the pickup roller is sticking on. See:
http://www.fixya.com/support/t16764902-s...
このアンサーは役に立ちましたか?
スコア 7
5 件のコメント:
This is true. I removed old adhesives and placed some electric tape instead. It is working now.
さんによる
exactly. i just put a piece of tape over the half moon rubber that sits on top of the coil and problem fixed. thx
さんによる
Holly molly it F*ing worked!!! Mine was A Samsung (HP rebranded) ML-1640 which was picking up 2-3 papers if I was trying to print more than 1 page. I dissasembled everything and got to the solenoid. The thing had a black sponge between the plate and the magnet and after 10+ years the foam converted to a sticky mess. I simply put wood tape on top and now it works like new! Also if anybody has the same printer, use SprayWay 203 spray for pickup rollers since one big black roller before the fuzer, is hidden behind the PSU and logic board.
さんによる
I agree with others who found it a chore to get at the Samsung ML-2010 laser printer’s solenoid.
I found the Disassembly and Reassembly chapter (Chapter 5) in the Samsung ML-2010 Service Manual (https://www.manualslib.com/manual/232534...) very helpful, with excellent instructions and diagrams.
The steps I took to get at the solenoid (with references to Sections in Chapter 5) were as follows:
1. Remove front cover (Steps 1 and 2 in Section 5.2.1)
2. Remove SMPS cover (Steps 1 and 2 in Section 5.2.4)
3. Remove main cover (Steps 1 thru 4 in Section 5.2.5)
4. Remove Fuser (Steps 2 and 3 in Section 5.2.9)
5. Remove Engine Shield (Steps 2 and 3 in Section 5.2.10)
6. Remove Paper Path Frame (Step 2 in Section 5.2.12)
7. Remove solenoid (Step 4 in Section 5.2.12)
さんによる
Just wanted to add my thanks for this solution. Although disassembly/assembly was a bit challenging, the solenoid was the problem, or at least adding electrical tape to the factory pad on the solenoid actuator appears to have solved my problem. Thank you to all those who spent their time and energy helping others.
さんによる
コメントを追加
Hey Dan. Are you the Dan Rae in NZ? I don't know that particular model but the fault may be the paper separation pad. It sits below the paper feed roller and may have become glazed. Either replace it or buff it up somehow.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi!
I would say if it’s just a single pickup shaft spin during certain period of time - and you having problem with second paper being picked up - that could be separation pad that is worn (and should be replaced), but if that shaft spinning twice during one pickup cycle and that is causing double pickup - that’s issue with solenoid (foam pad it’s not good in there and could be replaced with 2 cut pieces of any duct tape).
Good luck!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Dan Rae さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 33
過去 30 日: 139
今までの合計 15,192
