メインコンテンツにスキップ
iPod Touchは第7世代モデルまであります。
2619回答 すべてを表示
Backlight gone after suspected water damage?
I have a 2g ipod touch that has probably had water damage. My sister claims that it has never been submerged has but both the internal and external sensors are tripped. Everything is working fine except the backlight will not turn on. I tried swapping out the LCD screen but that did not solve the problem. I've taken out the logic board and cleaned it all and there are no obvious corrosion spots. Anyone have any suggestions?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
this just happened to me today.
you're better off just leaving it be and getting a new one.
thats what im doing..
there is nothing that you can do at this point.
さんによる
コメントを追加
3件の回答
ベストアンサー
I work on broken iPods all the time and we get water damaged iTouches in all the time. The backlight is built into the LCD and we'll try an LCD but the vast majority of the time, there is some kind of short in the motherboard that affects the backlight circuit. Your situation sounds all too similar...there isn't anything you can do at this point, I'm sorry to say.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I had that issue with an iPhone 3G in water. At first, I said it was the LCD. Then I've tried putting it's logic board into a working iPhone and I've had THE EXACT SAME ISSUES. So, sadly it's the logic board! :(
さんによる
コメントを追加
try reseting it or putting it in dfu mode and restoring your ipod. search how to put your ipod into dfu mode if you dont knwo how
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
sry about the spelling my keyboard keys are small
さんによる
good luck fixing your ipod
さんによる
コメントを追加
There is actually something you could do, but it takes some serious soldering skills from what i gather. The "6R8" coil is most likely fried, you can find them on eBay and other suppliers for about 15 bucks, but like i said its soldered on the logic board. Google 6R8 and youll get some hits.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I agree with joseph. I bet the coil got shortened out. You really have not much to lose by trying to fix it, steady hand some good magnifying lights and you might get it accomplished
さんによる
I have the exact same problem with my 2nd generation. i am going to try the soldering thing if i can find this 6R8 coil. if it works i will be sure to tell you how it went.
さんによる
コメントを追加
回答を追加する
Sarah Smith さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 7,796
