batterey replacement fir my Mini Maglite AA
I did what you said but when I removed the disc there is another
black plastic device that looks like it has to come out the other end because there is a lip holding it in place
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Unscrew the cap on the end opposite of the light bulb.
このアンサーは役に立ちましたか?
The answer above, "Unscrew the cap on the end opposite of the light bulb." doesn't answer the original question regarding removing the second piece of plastic under the lightbulb holder. So, no, the question was not answered.
このアンサーは役に立ちましたか?
You can gently pry that black cap off using a small flathead screwdriver. Under that you’ll see a black piece that holds the bulb in place and the electrical connections. Push that backwards out the end of the tube away from the head.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 22
今までの合計 1,413
1件のコメント
I tried to take the end cap off with two wrenches and it wouldn't budge.
It's now soaking in WD 40 and hopefully that will work.
If not it'll get the deep six!
rondon さんによる
