メインコンテンツにスキップ
A laptop by Toshiba with a 15.8" display and runs Windows. Has a straightforward repair similar to most laptops. Requires only a screwdriver.
5回答 すべてを表示
K O'd my laptop
In a fit of rage and stupidity ,I slammed my laptop closed and now it is inoperable. I have a windows Vista factory out of the box recovery program but it will not recover. It will load first disc and second disc but 32% through the recovery it has an error and shuts laptop down. Do I need a replacement laptop along with anger management ? Lol
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
Hi Ebert, While the machine is running, place your ear next to the machine and listen for any signs of hard drive failure. Provided you have a mechanical hard drive, sounds of spinning up, clicking/clunking and then spinning up again, etc. may be signs that you accidentally damaged the hard drive. A healthy mechanical hard drive has somewhat of a chattering/popping sound. Also--depending on just how hard it was slammed--It may be a good idea to 're-seat' the memory, as a poorly seated chip may become partly dislodged in the even of jarring. Start there, and please let us know how it goes.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ebert Williams さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 258
