Why is my battery not charging but the battery is working?
my nokia 610 will not charge9have tried with two batteries.one of the batteries is brand
new.
このアンサーは役に立ちましたか?
vneomai, how do you know it's working? How do you know it is not charging? If it is not charging, how do you keep the battery working? If your phone works but the battery does not charge in your phone, you either have a bad cable, a bad connector or problems with the power management circuit on your phone. Start with the cable and work your way up from easy to complicated. You also want to try a new battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 907
