メインコンテンツにスキップ
The Honor 3C is an Android smartphone produced by Huawei and released in December 2013 for 3G, April 2014 for 4G, and August 2014 for 3C Play. The Honor 3C can be identified by model numbers H30-T00 and H30-U10.
33回答 すべてを表示
Can I replace baseband from liquid damage?
Hi Guys, my huawei honor 3c fell in water. Everything works except for the sim card function. Is it possible to have the 'baseband'(as i'm told) replaced/ repaired.
An alternative would be having a new motherboard if at all I can find one.
I really like the phone, and won't buy another as this one means a great deal. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Hello kevin mutiso,
  • Check the SIM voltages between Vsim (1) and GND (4) Pins and it should be 1.8V
  • Any Observation around SIM card slot components or contacts corroded? - if yes clean them
Let us know the status and we can help you to fix it. Indeed kevin, actually Honor 3C is a good product which coming with IPS panel.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Tom Riddle さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 338
