メインコンテンツにスキップ
Android 4.0 tablet for children/ blue back cover and white face/ released 2012
26回答 すべてを表示
How can I fix the charger piece on my Kurio
I need to know how to fix the charger piece on my Kurio
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
4件の回答
最も参考になった回答
I have successfully replaced the micro USB connector on a Kurio tablet and documented the process here: Repairing Kurio Tablet Micro USB Connector (charging port). However, as Miles noted, this is a very difficult repair, so I would not recommend trying it unless you are comfortable with soldering at fine pitches. Simply replacing the mainboard with a new one from eBay would be significantly easier.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
The charger piece is chipped can u please help me fix it on my kurio 7 s tablet
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi from the pictures i can find of the motherboard it looks like the charging jack is soldering to the motherboard and to replace it would require a new one to be soldering on. I was unable to find a replacement jack so one would need to be pulled off another board. This will require someone fairly skilled in soldering to fix it. And unless the tablet has super important data on it i would either recommend buying a new tablet or one that uses a much more standard jack for charging such as micro usb on a nexus 7 or 8.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Kurio charging port Bent
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Good and helpful
さんによる
コメントを追加
回答を追加する
Shermaine Maxwell さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 7
今までの合計 3,291
