メインコンテンツにスキップ
The GoPro Hero3Plus Black Edition can be identified by its model number: CHDHX-302. It's an eighth generation camera that was released in October 2013. The GoPro Hero3Plus Black Edition is a Wi-Fi capable, 4K resolution digital camcorder.
HDMI port has caved in. How do I fix it?
My HDMI port broke and needs to be repaired. I'm not sure if I am going to have to solder the connections or just use some crazy glue. Im scared, actually terrified of tearing it down then realizing that I cant fix it with my limited knowledge of and experience with soldering very small connections, and etc. Anyone that can give me any advice at all concerning this would be greatly appreciated.
Thank You
mishmael
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
There is a take apart video of a fellow that had the same problem with the USB connector. When his disassemble his cam and got to it, the pads were lifted from the motherboard and because of the compactness of it, there is no way to repair that. A new mobo will solve the problem.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
Mobo ? What's a Mobo ?
さんによる
motherboartd
さんによる
Oh ok I'm not sure if I am going to replace the entire motherboard that sounds expensive
さんによる
コメントを追加
mishmael, remove the logic board by using this guide. That is the easy part, the hard part will be to source the port and find somebody that can microsolder. I'd try places like Digikey or Mouser to try and find a replacement. There is plenty of space to solder for the right person. No you cannot use crazy glue. If you want to go and replace the motherboard, it is available right here
Main circuit board assembly for the Black Edition of the GoPro Hero3の画像
製品
GoPro Hero3 Black Motherboard
$19.99
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
The parts are fine the port is in great shape just need to micro solder but I'm also terrified of opening it up
さんによる
mishmael254 got to start somewhere to repair it. If you do not think you can do it, check some of the numerous GoPro repair service centers online.
さんによる
コメントを追加
回答を追加する
mishmael さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 17
今までの合計 4,114
