How should I repair lcd light?
lcd light not working
Check the screen to board connection, if it seems to be properly seated, then you will want to order a replacement LCD screen here. I found this video which goes through the disassembly process. If you are only replacing the LCD, then you will want to stop watching at 4:10.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 85
