Why I can't charge my phone
My charger piece in the inside of the phone where i charge my phone is damaged how can i fix it
Hellow Caleb Ragsdale,
you can simply change the [http://daughter card |Why I can't charge my phone]
here is the teardown guide
if you have sound soldering skills you can change the charging port and it will cost around $2
このアンサーは役に立ちましたか?
I had my prongs bent in by someone so I want to connect positive and negative inside to my charger wires BUT it has 2 red 2 black and 2 white, what to do? :( its a alcatel one touch fierce xl :( . + and - not labeled.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 1,157
1件のコメント
i want where to take phone it to fix the charge pots
diamond さんによる
