メインコンテンツにスキップ
セガジェネシス(通称メガドライブ)は、現在までにセガが最も成功したビデオゲーム機です。
37回答 すべてを表示
Why did my console stop working?
Hello!
I'll cut to the chase.
Yesterday I dug my Sega Genesis out of my closet. It was on the top of the pile face up, it still has the dust protector and everything.
Anyway. After hooking it up, I put my one game in, sonic spinball. I played for an hour and a half then just hit the power button to turn it off.
Today I have a friend over, and I want to show them the Genesis since they've never seen one before. I turn the TV on and, what I believe to be the copyright screen, or the screen before the "SEGA" logo shows up. But after that screen, it fades and stays black. And doesn't load up the Sega screen. Or anything beyond that. No music plays or anything.
So I hit reset. Same thing.
Then I pop the cartridge and do the standard "lightly blow to dislodge dust". Pop it back in, still same results. Hit reset again.
This time, I don't even get that copyright screen. I get nothing.
Now I'm not sure what to do. Because I don't have other games to test with, and I don't imagine a game goes bad overnight.
Help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
ベストアンサー
See if this helps, first off try a different cart to see if it's the connector pins or just the cart itself. If it's the cart you'll need to get some q-tip and some alcohol and clean the cartridge until no more dirt is visible on the q-tip. If it's the pin connectors try taking a credit card, wrap some paper towel around it and clean it with alcohol and really get in there. If that doesn't help then you might just need to get a new one, unless you are handy with electronic repair.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alex K さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 658
