メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2012年3月16日に発売されたiPad Wi-Fi機能搭載の第3世代モデルです。モデル番号はA1416です。修理には温めて、慎重にこじ開ける作業が必須です。
new digitizer not working
What am I doing wrong? I'm on my third digitizer now, but its still not working.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I replaced the broken digitizer onmy iPad 3 with cellular data. I also replaced the battery, and left cellular antenna that I damaged removing the broken digitizer. After reassembly and power up, the new digitizer is un-responsive. The screen is blinking, and it keeps saying " screen lock, muted, ". I adjusted the volume to check for pinched keys, I disassembled and checked ribbon connectors. I don't know why, but it's freaking out man.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Blow the digitizer connector port on the logic board so that any foreign stuff gone inside will be out. Or check with a magnifying glass if you can notice any. Check if you are securing digitizer latches properly or you broke them off. Sometimes just the screen comes bad multiple times. Do not freak out as EyeSpyInc mentions. Most of the time either the screen came with dead digitizer or the connector latch is not secured. Hope it helps.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Yeah, I've had glass shards in the connector cause the pins to get bent out of shape when inserting the digitizer FPC. Was fortunately able to bend them back without issue, in that particular instance.
さんによる
コメントを追加
回答を追加する
Terrance Busari さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 10
今までの合計 226
