メインコンテンツにスキップ
Apple iPhone 5cは2013年9月10日に発表されました。このデバイスの修理は前モデルと類似しており、スクリュードライバーとこじ開けツールが必要です。GSM か CDMA、8, 16, 32 GB 、色は白、ピンク、黄色、ブルー、グリーンがあります。
1235回答 すべてを表示
Dropped my phone now I have colored lines on the entire screen
I dropped my iPhone 5c on a hard surface, and when I picked it up I saw pink/red lines across the screen. After I hit the lock button, the screen is normal but after about 10-30 seconds pink and red vertical lines appear across the screen and it stops functioning until I press the lock button again. Is there a way to fix this problem or does the LCD screen need to be replaced?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 31
25 件のコメント
Just happened to mine and it won't work but I can never get service and I got it after I dropped it
さんによる
I have a 5s I never dropped it or boyging I went to check the time n there was a green line so I cluxked the power button and it never turned back on , can I take it somewhere yo be fixed or is it done for?
さんによる
Is this optional? I can live with the lines in my screen. I just want to know if I dont fix it, nothing bad would happen.
[After I wrote this comment I noticed the lines faded away. You'll be fine. Sometimes they fade away. Just wait.]
さんによる
My phone fell and it started like blinking with no-colored lines on the screen. I hit it again to see if it stopped, and it did, but then I turned it off for it to "rest" for about an hour. When I turned it on, the blinking appeared again. It still works but sometimes it stops and sticks in the screen. What can I do, rather than changing the LCD display. Plzzzzzz helpp!
さんによる
Don't worry I have a iphone 5 SE and that happened to me I let it sit for 5 minutes went back to normal
さんによる
20件以上のコメントを表示
コメントを追加
10件の回答
ベストアンサー
Yes, sounds like you're going to have to replace the lcd panel. The good news is it's very easy to do on a 5C
iPhone 5c Screenの画像
製品
iPhone 5c Screen
$27.99
このアンサーは役に立ちましたか?
スコア 9
8 件のコメント:
Will a soft/hard reset solve the problem too?
さんによる
how on 5c just happened to me
さんによる
How exactly do you replace the lcd panel?
さんによる
is this easy to do on an iphone 5s?
さんによる
Is this optional? I can live with lines on my phone. I just want to know if my phone will glitch out like crazy or anything if i dont fix it.
さんによる
3件以上のコメントを表示
コメントを追加
The display cable may have come loose, so before you replace the display, follow this guide and make sure that the display data/digitizer cable is properly seated and is not loose. Disconnect the device from power and shut it down before opening, and disconnect the battery before attempting to touch any other connections. Reassemble the device and turn it on. If this doesn't change anything, you can order a replacement screen here.
iPhone 5c Screenの画像
製品
iPhone 5c Screen
$27.99
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
To tell you the truth... My mom gave me her hand-me-down government phone(getting a phone mabey for Christmas), and she dropped it at the store and claimed her battery was low on her phone. So when I looked at the screen, I saw green, blue, purple, red, and yellow lines going vertical (up and down) on the screen. Fortunately, the phone still works, but it's really annoying that I can't play my minecraft because of this situation.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
You will need to replace the LCD extremely easy to do on a 5c luckily you can get a new on eBay for $20
さんによる
is it just the panel Austin or can i get a new screen
さんによる
or do i just get inside
さんによる
How do I replace the LCD.
さんによる
コメントを追加
You need to pop your finger in bottom...it might not fix it, but it will distract you for a short time.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I dropped my phone and the screen shattered. It still works, but there are color streaks. Is that just a side effect of the cracked screen or is something else damaged too?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It's just a cable came out of the socket all you have to do is go into the screen and make sure all the cables are hooked in properly
さんによる
コメントを追加
i cant even see my screen nore answer phone calls its so annoying I have had enough
Update (03/06/2018)
it works but it doesn't let me see any thing on my phone at all and not only I cant see any of my texts or phone caller id no more as the phone has given in on me and now cant use it again
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
this happened to me too. I am getting a replacement phone and sending the broken phone back so they can fix it. try that
さんによる
コメントを追加
Hi I ordered a screen for my grand prime but instead a duos screen came, Can I work for my phone?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Idk, my phone is having gray lines horizontally across the screen. It is the iPhone 5c. I am anxious to go to T-Mobile to get it fixed. Does anyone know what is wrong with it? It happened after I dropped it. It was fine for about five minutes then I was sitting down and the lines were there.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
This is happening to my phone as well after i dropped it. Ugh I can't even watch Netflix.
さんによる
コメントを追加
My iPhone 5c keeps on restarting and also leaved some lines on the screeen any time it's goes off.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I really want to know the course. Thanks
さんによる
コメントを追加
You will need to replace the screen assembly. I would first check if the connection has come loose!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Craig Spring さん、ありがとうございました!
統計データ:
過去 24時間: 18
過去 7 日: 108
過去 30 日: 457
今までの合計 474,811
