メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Harley-Davidson Sportsterモーターサイクルの1986年モデルから最新モデルまでの修理ガイドです。
Why does my oil light come on when the motor gets warm?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント:
You might want to make sure you are using a straight 30w, or heavier, oil and that the oil is not broken down by heat or contaminated by gas/solvent. If it is not the oil itself, then it could be the sensor (hopefully) or some bearing is getting loose enough to impact the oil pressure when everything's warmed up.
さんによる
If you are using 20/50 and your oil level is within spec after it has been warmed up then you have an oil pressure issue. For a quick test, with the bike running, look into the oil tank. Do you see air bubbles and the oil moving? Another quick test: Place a pan under the oil filter > remove oil filter > start bike (it'll take 10 sec of run time). Do you see any oil being pumped out from the feed line into where the filter would be?
さんによる
コメントを追加
1 件の回答
Noah is right.
Another possibility is degraded oil and more probable, a worn oil pump.
( a tooth wheel pump )
Change the oil and look carefully for metal-chips.
Check ( by taking it to pieces ) your oil pump then!
Good luck !
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Michael さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 14
過去 30 日: 33
今までの合計 4,073
