メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
締切られた回答
How to test individual pieces of hardware
So I have my laptop in pieces now after a liquid spill (bought a new keyboard and cleaned the logic board of corrosion) and I'm wondering how I can figure out which, if any, components are damaged. After the spill I was not able to get back into the computer normally (my usual administrator password was not working despite using an external keyboard to type it, password hint same as always). So I'm wondering if maybe the hard drive is damaged? Should I just put the whole thing back together and see what happens? I saw somewhere that you should put in one element at a time and test those somehow but I can't find any more information. I'm very new to this so any help would be appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Your hard drive and password should not have been affected. It is case sensitive. The hard drive is accessible via Target Mode. I'd just put it back together. If you were getting any beach ball delays before the spill, I would replace the Hard Drive/IR cable as there are known issues with a lot of them.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 6
今までの合計 97
