Where are the GPS unit and its connections?
A couple of weeks ago, I stupidly opened my Evo 4G, attempting to remove some water from the screen. I destroyed the display in the process. That was easy enough to fix. However, I later discovered that the rear speaker wasn't working. Apparently, in removing the inner frame from the display assembly, I had damaged some contacts. The first I discovered was the top spring contact on the right-hand side. In trying to get it back on, I lost it, but didn't notice any change in the phone's operation. I then noticed that one of the little "bowl-in-a-box"-shaped parts along the right-hand side of the sticker had been pried up on one side, and that a wire beneath it had been ripped off its contact. I did my best to solder all three back in place, and the speaker now works.
However, I then discovered the GPS doesn't work. I eventually found and resoldered the missing spring clip, and applied to iron to the bottom "bowl-in-a-box" part on the right-hand side, which seemed to be possibly loose. Neither of these things affected the GPS (or, as far as I can tell, anything else).
Does anyone know how I could have broken the GPS and what I might do to fix it? One hint I have is that the two parts I broke were underneath holes in the inner frame (the teardown video is unclear, and at first I couldn't figure out where to stick my tool).
Thanks,
Scott
この質問は役に立ちましたか?
1件のコメント
+ vote for your success!!
mayer さんによる
