The File is Damaged and Could Not Be Repaired
How to Resolve PDF Error – "The File is Damaged and Could Not Be Repaired"?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Sometimes a PDF file becomes damaged or contains corrupt data. If you downloaded the PDF from the Web or received it in an email, download the PDF again or ask the sender to resend it. Copy the file directly to your hard drive, rather than a thumb (portable) or network drive.
Open the new copy directly from your hard drive.
Read more: http://www.ask.com/answers/680343921/how...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 112
