メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5cの修理情報とガイドです。モデル A1532, A1456
1233回答 すべてを表示
Proximity sensor not working after screen replacement
Hello.
I have replaced my mom's screen on her iPhone 5c as a Mother's Day present, and both her and I are happy with the results. Anyways, for the past 4 days, my mom told me that when she's on a call, she accidentally presses button not the call menu (mute, dial pad, end button, etc). When she told me yesterday, I immediately knew that it was the proximity sensor, and I told her that was fixable. Earlier today, I opened up my mom's iPhone, and noticed the proximity sensor bracket on the original screen. I transferred that bracket to the new screen and put the iPhone back together. I called myself from her iPhone to test the sensor. The display turned off for like a second and it turned back on. It did that for like 3 times before the sensor wouldn't work anymore. Later on, like 3 hours later, I opened it up again and reseated the flex cable. I put the iPhone back together and it didn't work. 5 minutes later, I called myself again and the sensor was working! Then 20 minutes later, I called myself again to make sure that it was working again, but sadly it stopped working. I don't know what to do anymore to fix this. I kept looking online to fix this problem, and they didn't help. Right now the iPhone is functioning without the proximity sensor working.
Does anyone know a solution to fix this? It would be greatly appreciated!
Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Hi Brandon,
It's very possible that you have damaged it, replacing it should solve your issue. :)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
You have to insert the sensor INTO the sensor holder.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I have inserted the sensor into the sensor holder. I double checked and it was on there securely.
さんによる
If nothing work, you have broken front camera flex...
Change it.
さんによる
コメントを追加
回答を追加する
Brandon さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 300
