メインコンテンツにスキップ
The Beats Pill is a small, portable Bluetooth speaker from the Beats by Dre line of products produced by Beats Electronics LLC. It features direct audio and Bluetooth connectivity as well as an internal microphone to conduct phone calls. This device is fairly capable of being repaired due to its intuitive construction.
32回答 すべてを表示
Beats pill not Charging
My beats pill is not charging. Can it fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 24
3 件のコメント
My beats pill won't work either I've been pretty rough on it and so when I plug the charger into the speaker I've accidentally pushed the metal part inside the pill and it won't charge
さんによる
mine is in great condition but when i plug it in nothing happens and after 3 hours of charge it did not turn on
さんによる
my beatspill has been broken for months and the metal part inside the charging part like moves around and when i put in the cable it just falls out! please help
さんによる
コメントを追加
6件の回答
最も参考になった回答
A very prevalent problem in lots of bluetooth speakers, including the Beats Pill. The micro-usb spec doesn't specify a robust enough attachment to the motherboard. Over the course of use, the jack is literally pushed off the PCB, sometimes (often) taking the traces off with it. The replacement of the micro-usb jack is very often not straightforward at all, particularly when the traces have been lifted off. If you have skills, it can be done, but if not........
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I had a guy push the wrong charger In it it bent the pins just need parts looks like easy fix I ha VB e eltronic skills where do I find those parts
さんによる
コメントを追加
You'll want to troubleshoot the issue to narrow down the failed component.
  • First check your wall outlet, make sure it's providing power
  • Check the charging cable against another, known working, cable to verify that works.
  • Use canned air like Dust-Off to clear out any debris in the charging port itself.
  • Use the guide on our website to open up your device and replace the charging port if necessary.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
MGOM. Bluetooth speaker trun off not properly
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What you need to do is charge it as much as you can than turn it on after that hole the "b" button and the power button hold it the red light from the charging input will turn green and back to red three times
It should work after
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Hi. I have done that but it won't hold charge at all do you have any other ideas? Thanks
さんによる
コメントを追加
My beats pill not charging
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Where can I get it fix
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Phinisia Thomas さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 20
過去 30 日: 27
今までの合計 43,625
