メインコンテンツにスキップ
1.83、2.0、2.1、 2.16、2.2、または2.4 GHzのいずれかのCore 2 Duoプロセッサーを搭載したModel A1181
1203回答 すべてを表示
Telling if my computer is of the Santa Rosa chipset?
The MacBook Core 2 Duo (Model A1181) w/2.4Ghz processor can accomodate up to 3 GB of ram normally. Computers with the 'Santa Rosa chipset' can accomodate 4 GB. How do I tell if I have a computer with the Santa Rosa chipset.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
the 13" Macbook Core 2 Duo was updated to the Santa Rosa chipset in Nov 2007. this model is aka MacBook 13-inch Late 2007.
According to Mactracker, the machine ID for this model is: "MacBook3,1"
this machine ID is unique to the particular version of a model, unlike the generic model number A1181 which spans several generations of this machine
you can find the machine ID for your MacBook by going under the Apple menu and select "About this Mac..." then click on "More info..." - this will launch System Profiler. your machine ID is listed.
if your Machine ID is "MacBook2,1" then you don't have the Santa Rosa chipset and you can only use up to 3GB RAM. if your Machine ID is "MacBook3,1" or higher you have a Santa Rosa machine and can use 4.0GB RAM as specified by Apple (actually, 6.0GB will work)
edit: you mentioned your machine is 2.4GHz - then it looks like your machine ID should be: "MacBook4,1" - this would be a "MacBook 13-inch Early 2008" version
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Great! Thanks a lot. You were correct in assuming that my machine id is 'MacBook4, 1'. You said 6 GB will work. Does that mean that if I put two 3 GB chips in then it will use all 6 GB or will it only use 4 GB? I remember seeing something about some of the computers only being able to utilize 3GB even though you might have put in 2 2GB chips into the computer.
Update: If found the answer at this link...thanks for all the help!
http://forums.macrumors.com/showthread.p...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jared さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 3,386
