How do I replace the keyboard?
The keyboard on my Dell Inspiron 15R is behaving badly. Pressing any of the keys below the Backspace key (pipe, forward slash, enter, shift and the arrow keys) causes the the cursor to backspace.
There will be four hinges on top of keyboard. Gently push the hinges up with a screw driver. Pull a bit up and take it out gently. DON'T PULL TOTALLY, YOU MIGHT TEAR OUT WIRE STRIP.Now you must pull and open the small cap holding the wire strip to the motherboard with nail or screw driver.Insert new keybord's wire strip and lock back the cap. Insert keyboard from top and press gently to lock back hinges.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 82
