メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2201回答 すべてを表示
Possible screen and/or digitizer damage.
Hi I purchased an Iphone, was told by the seller that it was a 5s model. It needed a new battery, so I followed a video to replace it only to find that when I pried off the front, there was no battery underneath. Further research shows that I actually have a 4s model. While they look very similar on the outside, they are not on the inside. Now the phone will not turn on, or the screen is black. Would yuor educated guess be that I have permanatly damaged the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Upon disassemble, the 4 corner tabs on the inside of the screen were broken off and a random small brass piece was found. A new screen was installed and the phone has been restored. Thanks.
さんによる
コメントを追加
2件の回答
ベストアンサー
Some people pretend to sell iPhone 5 or newest model using custom housing for the iPhone 4/4S.
Right now, Changing battery for iPhone 4/4S and 5/5C/5S is not the same.
To acess battery for iPhone 4/4S, you have to remove rear glass panel.
Conclusion, your LCD is probably damaged and you have to change it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
最も参考になった回答
Do you mean you received a iPhone 5 as there is plenty off difference if it was a 4s
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
It is a 4s, I was told it was a 5s when I bought it. 4s: change battery from back, 5s: change battery from front.
さんによる
コメントを追加
回答を追加する
Paul さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 4
今までの合計 115
