motherboard just beeps doesnt display
motherboard doesnt displa even if i insert ram
Usually this the result of either an incompatibility with the ram you are trying to use (I know of NO motherboards that will boot without RAM installed). Can you provide the model of your motherboard and the exact specifications of your RAM chips (there should be stickers on the chips with this info). I can help you better with this info.
このアンサーは役に立ちましたか?
I think it's because of the incompatible RAM too.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 935
Can you tell us which motherboard is it, What did you do to fix it, any tried steps? how many bees you can hear?
Buddhika Mahesh さんによる
