メインコンテンツにスキップ
Strong, small, and stable, the Hubsan X4 107L is an excellent quadcopter for anyone learning to fly RC aircraft.
Drone is flying backwards why is That?
My drone flying is reversed all the air is pushing from the top so it stays grounded and doesn't go up what is the fix please
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
ベストアンサー
Hey Saad,
It sounds like you have your props placed incorrectly. There are two clockwise and two counter-clockwise motors which, in turn, use clockwise and counter-clockwise propellers.
If look closely at your quad, the ends of the motor arms are labeled either "A" or "B":
Similarly, each propeller should also be labeled "A" or "B." Try swapping props so their letters match their arms and you should be good to go!
このアンサーは役に立ちましたか?
スコア 6
1件のコメント:
Hey Evan, the arm and the props have marks A & B but how to figure out which part of the prop will face in front or back ? i mean the angle of the prop ?
さんによる
コメントを追加
回答を追加する
Saad Qureshi さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 15
今までの合計 5,868
