メインコンテンツにスキップ
BlackBerry's newest flagship that features a physical keyboard.
73回答 すべてを表示
Can blackberry passport water damage be fixed?
My blackberry passport fell inside water. i picked it and dried it and it worked for about a week till it suddenly went off and won't power up again.
I've taken it to the repair and i'm told i need to change the panel which is unavailable in the Nigerian market. please where can i get the panel. also will it be possible to fix this phone
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
No change for main board needed ask technician to remove ( brake ) one rectangular resistor between battery connector and display connector. If phone have water inside this resistor change and drain battery to 0 and prevent charge. I do same on may Passport and it working after one minute charging.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
yes its possible the phone will work, what ill like you to do is to contact me or watsap me on 08030732622,you be happy you did
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
hi chucks kindly sendme a watsap message on my contact,im based in Abuja we will discuss how in get the phone for repair
さんによる
コメントを追加
回答を追加する
chukseboagwu さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 1,792
