washed my phone in washing machine
Accidentally washed my Galaxy S5 in washing machine. What do I do now?
saperkins01, just like any other device that has been liquid damaged. First thing you want to do is stop using it. Do not turn it on, or try to sync it etc. Disassemble your phone and remove the motherboard. Follow this guide. Then clean every part with 90%+ isopropyl alcohol (unless you have an ultrasonic cleaner) To clean your phone properly, follow this guide. It was written for an iPhone but all the steps are pertinent to your phone as well. Clean all the connectors, all ribbon cables etc. While you are cleaning it, make sure that you visually check the boards form missing components etc. Once it is cleaned and dried, reassemble and replace the battery. this is a must to avoid any trouble later on. Then try out your phone and check for any further damage. you may have to repeat the cleaning a couple of times. Always make sure that you remove all the EMI shields as well. Water damage is the hardest to diagnose and repair. Even doing everything right it may still never work again, but at this point you have really nothing left to lose on this phone.
ガイド
難易度:
難しい
1 - 2 hours
ガイド
難易度:
中レベル
30 minutes - 1 hour
このアンサーは役に立ちましたか?
I just put my husband's galaxy s5 phone thru the whole cycle in our front loader. It was in his pants pocket in its Otterbein. It works perfectly fine. It was absolutely dry inside. This phone is amazing!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 4,586
