What do I do if my LCD is cracked?
I dropped my camera and the LCD cracked and now I can't view my photos properly.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can purchase replacement glass covers for the LCD. To replace, heat up the screen with a hair dryer to soften the adhesive, then use a suction cup to pull it off. You may need to apply tape to the cracked area to get a good seal.
この回答は役に立ちましたか?
It's no good now. Better mail to me and I'll get rid of if for you :)
Seriously though, it's pretty easy to replace. The lcd is available on eBay for about $20. And I can't hotline to it but if you google d7000 dissection you'll get a good article on its tear down. Most of that you can ignore. Just do the first part till the lcd assembly is off. Then skip to the bottom to remove the lcd from the assembly and replace.
And invest in a good tempered glass screen protector!
この回答は役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 858
