Are I9300 and I9305 equal in display replacement?X
Hey,
I like to repair my Galaxy S3 I9305 device. There is no actual guide for the repair. Does anybody know whether it is the same way as the I9300?
They are the same. Only differences are the motherboard and the antenna module. I've seen a lot of people swapping those screens, you'll be fine without issues!
EDIT: If we are talking about the front glass****
The LCD are different and the way the phone is built too. It won't fit and you may have problem fitting the whole thing.
Regards,
Bruno
このアンサーは役に立ちましたか?
Your answer is misleading. You should've just said that the screen frames for each model won't fit on each other vice versa.
i9300 screen LCD with frame won't fit with i9305 for example.
Hi,
I've one Samsung S3 i9305 and my display is broken
But in Brazil I can't found lcd i9305 just to i9300,I want know if I can buy and replace?
My question is because I saw some sites offering LCD which works in both models.
How this Advertisement below:
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 1,054
