TRASH BUILDUP will not empty all.
I GET A MESSAGE AFTER A SHORT TRASH REMOVE LOCKED ITEMS
OR REMOVE ALL ITEMS.WILL NOT EMPTY ALL LEAVES THOUSANDS IN THE TRASH
CAN YOU HELP ME? THANK YOU BERNIE
b.lunning@sbcglobal.net
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Your question is tough to comprehend when punctuation is left out, but I think I get the drift. Either some of the items in the trash or associated files are being used by the system, or the system isn't granting you permission to delete these files. I would suggest you check all background processes and repair disk permissions using Disk Utility. This link should help.
このアンサーは役に立ちましたか?
Very good + Ralph
+ nice link ;-)
There are keyboard shortcuts you can use force your Mac to empty the trashthat you should try first. You can Control-click on an item in the trash and select Delete Immediately, or you can try holding down the Option key while emptying the trash.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 784
