Nexus 7 2013 Locked up can not turn on
it locked up ,turned off would not restart. while plugged in no battery charging icon visible.any way to turn it on?pressing vol and power at same time has no effect.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Robert,
How long did you hold the keys down?
For any one else reading this:
Recovery Mode
If your Nexus appears to lock up during any of these steps, you can restart it by pressing and holding Power for a few seconds.
Some mess up the above and get 'no command' and the android guy on his back on the screen.
Try this:
Hold the power key and tap the volume up key. then release the power key. This will get you to the next step. That is the command it is looking for. It is an additional step to make sure someone does not enter this mode by mistake.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 8
今までの合計 587
