メインコンテンツにスキップ
2012年半ばモデル、A1278/2.5 GHz i5または2.9 GHz i7プロセッサー。
1624回答 すべてを表示
Screen backlight not working on my MacBook Pro
I accidentally dropped milk on my Macbook. Few amount of milk has seeped into the left side space between display screen and keyboard.
I dried it and left it for few days. Later I started it. I can hear the startup sound and cooling fan goes well but my screen went black. I thought the lcd / led screen was dead but on further investigation (shining a light through the apple logo) I found that the screen is working fine, its the backlight failure.
How can i fix it...?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I'd check the backlight fuse first. It's on the board near the lcd ribbon connector. Should have a letter "P" on it. Did you actually open the macbook and dry everything or just put it in like a bag of rice?
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
I opened the macbook and dried it using a hot air blower
さんによる
That does nothing but spread around the $@$*. Put it in a tupperware container of 99% alcohol and toothbrush it gently in circles to remove the junk, hopefully the hair dryer didn't ruin the board.
さんによる
@c3pt how do I "check" the backlight fuse? I found it... now what? Thanx!
さんによる
You can check it by using a multimeter, putting it into resistance/continuity mode, and put the red probe on one side of the fuse, and the black one on the other side (polarity doesn't matter), and there should be a ~0Ω short across the fuse.
さんによる
Look for any burn / black marks on the LCD connector too.
さんによる
コメントを追加
回答を追加する
Dinesh Kumar さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 126
