Washer wont drain or spin
we recently replaced the clutch and washer worked for a while. It then started making very loud noises when draining. It then stopped draining or spinning. It does agitate.
typically when a washer won't drain or spin it's because the lid switch is bad. It's a safety mechanism that prevents the washer from draining or spinning when the lid is open (for very good reason as when accidents do happen during a spin cycle with lid open, they tend to be fairly grusome)
It's never a good a idea to just throw parts at a machine before you identify a part as being bad, but no spin/ no drain is almost always a faulty lid safety switch
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 1,061
