メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3もしくは3.6 GHz Core i5プロセッサ
Fuzzy loading screen then white.
I was told it was a hard drive issue but am unsure if it is. The fuzzy screen with the loading makes me think gpu. If it is gpu where do I get a replacement? The first 2 pics are of normal boot. The 3rd pic is safe boot and specs. pic 4 is of the entire screen in safe boot.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
3 件のコメント
Can you take a snapshot of the screen so we can see what you see. Post it here by editing your question and using the ribbon menu button on the far right in the dialog box.
さんによる
thanks for the reply hope those pics help.
さんによる
コメントを追加
1 件の回答
ベストアンサー
At this point it could still be the LCD display or the LVDS cable or the GPU card. Its clearly not the Hard drive.
Do you have an external monitor which you can plug in to see if the problem follows? If it does then its the GPU card, if not then the internal LCD display and/or the LVDS cable is damaged.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I do have 2 monitors. 1 hdmi and 1 dvi. I will get an adapter and try that.
さんによる
I connected my external monitor to it and it looked the same as the imac in dual display. I guess finding a gpu is my next step. I assume I have to open up the imac and find out what gpu i need, or is the specs that i pulled up in safe mode all the info I need to buy the correct gpu?
さんによる
コメントを追加
回答を追加する
ishkapiddle さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 8
今までの合計 468
