メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
iPad Miniは7.9 インチのディスプレイで、容量は16、32、64 GBがあります。
Ghost touch when screen gets pressed
I have tried several screens, the touch works if the screen it straight out, but once its laid down it goes crazy, even more when its pressed down on any side. I have tried the tape on the cable my the home button, tapping all the bottom part of the digitizer, co ering all metal contacts, etc. Still no luck, even after trying several screens. Help?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
5件の回答
最も参考になった回答
Any dents or dings on the frame?
Sounds like the digitizer isn't lining up right causing the ghost touches. This is usually because the frame is bent causing the digitizer to be pinched for lack of a proper word. I use a G Tool to remove major dents and a file for the little ones. Its always better to take care of every dent you see to prevent this kind of thing.
If there are no dents or removing the dents didn't fix the issue, the problem is going to be on the digitizer connector to the mainboard. A good dose of 99% IPA should clean it out and fix most issues. If that doesn't fix it, examine the connector under a microscope. Any scratches? Any issues at all with the connector? A broken connector is a pretty straight forward hot air solder job. If you see scratches or damage to the traces, you have a fun micro soldering project.
Use plastic tools when disconnecting the digitizer cable to prevent damage to the connector and the board. Its way too easy to use a screwdriver or metal spudger and scratch something that will end up costing you hours in labor for not taking 2 seconds to pick up a different tool.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Make sure the digitizer cable isn't getting pinched between the glass and metal chassis. That could be causing the glitches.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Not pinched at all, it folds nicely on the gap by the lcd cable.
さんによる
コメントを追加
Use 2 layer of adhesive and the problem will be gone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What is "99% IPA" What the heck; I have to type 20 characters in order to get my question published?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
isopropyl alcohol
さんによる
コメントを追加
What do you use to clean the connector cable with IPA (IsoPropyl Alcohol)? Do you submerge the cable in it? Do you just clean it with a lint free cloth?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
theperformer19 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 570
