メインコンテンツにスキップ
13インチアルミ製Unibody, 2.0 or 2.4 GHz Core 2 デュオプロセッサモデルです。
574回答 すべてを表示
Upgrade a late 2008 unibody 15'' from 2.4GHz to 2.66Ghz
For context, my logic board died (overheated after installing a new hard drive). It was a 2.4Ghz version of late 2008 unibody 15'' Macbook Pro.
I finally decided to repair it as you can find logic board for about $250 on ebay now and the one I'm looking at is a 2.66GHz logic board. It really looks exactly the same, from a shape a connector stand point so I was wondering if I could just "upgrade" to this new logic board.
Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
Antony,
It will depend on the specifics of the 2.66 GHz logic board. Several MacBook Pro models since Late 2008 were available with a 2.66 GHz processor. If the logic board you are looking at is for an early 2009 MacBook Pro 15" (Model MB470*/A), it should be compatible. Any other model, however, will not be.
Good luck!
Kevin
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antony さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 110
