メインコンテンツにスキップ
The second generation HTC One—dubbed the HTC One (M8)—features a dual flash and the new Sense 6 UI, and was released March 25, 2014.
202回答 すべてを表示
Which replacement to use for a weak USB port?
My USB port seems to be weak. It's only charging if I hold the cable in a certain position.
Cleaning the USB port didn't help and I tried several different cables.
Want to replace the USB port and I'm wondering what's the difference of the "Charging assembly" and the "Headphone jack and USB assembly"?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
In fact, they are the same thing. But USB port is different from the assembly. HTC One M8 charging assembly also called USB board is coming with USB port and headphone jack just like that. It's much easier to replace the whole assembly if you need to repair. While replacing USB port only is a little difficult and complicated because it need to be soldered.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Philipp Hofstetter さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 251
