メインコンテンツにスキップ
iPhoneの第2世代モデル。モデル番号はA1241 / 8 もしくは16 GBの容量/ ブラックもしくはホワイトのプラスチック製背面ケース。修理はオリジナルiPhoneに比べて直接パーツに作業ができます。ドライバー、こじ開けるためのツールと吸盤カップが必要です。
1158回答 すべてを表示
iPhone keeps losing service after I dropped it
I dropped my iPhone 3g the other day. Now it keeps losing service off and on sometimes it gets service and I can get text messages and make calls, but then loses service in like 30 seconds even though I haven't moved it. My phone is also jail-broken for t-mobile.
Please help me out; my wife is super mad because I just got this phone after I broke my other one.
(This is a question asked by Steven from our discussion forums that did not get an answer. We'll see if you guys can help!)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 3
1件のコメント
I have 3g 16gb iPhone. I can hear from the phone the speaker and headphone works. all other functions works.
さんによる
コメントを追加
13件の回答
ベストアンサー
Sounds like a loose connection for the antenna.
このアンサーは役に立ちましたか?
スコア 5
コメントを追加
Every time you lose service, a much faster way to get service is to turn airplane mode on and off. Also, have you updated your iPhone to the latest software? If you haven't you should do it. And if all this does not work, try restoring your iPhone and get it swapped out at the genius bar. But don't tell them you dropped it. They have no way to find out! Also un-jail break your phone before you take it there.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
The problem is a loose cable. Open the iPhone through iFixit steps and reconnect the cables and you are fine.
I have fixed a lot of phones this way with the same problem.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Remember kids, good spelling and grammer saves lives.
さんによる
Ironic. You misspelled grammar. Maybe you should fix yours.
さんによる
コメントを追加
Depending on your current firmware, updates also update the radio's baseband. I was having the same problem for a while until i did a full update. Carriers will always change their network configurations to increase their data speed. Also before you do so, back up your files and do a complete reset all settings from settings/general/reset all settings. It will take about an hour. This will erase any registry file value that could be causing the issue. Hope this helps.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
When you dropped your phone i think you have damaged your mother board. I had an incident with my iPhone 3G and now it will only pick up 3G signal. Take it to an Apple store and see if they will replace it for you. I don't think there would a DIY solution for this.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had the same problem and had to replace the antenna and antenna flex.
It takes a lot of patience to do it, but it works fine now!
total cost: €20 (or 30 dollar something)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
This may sound strange, but I believe if the SIM isn't seated properly this can occur also. I think it's much more likely the antenna is damaged though, the flex cable is delicate.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hate to state the obvious, but have you tried a reboot?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
I think you can't comment until you have 30 reputation, but in the future this would be better as a comment instead of an answer.
さんによる
You still need to understand Nate, the major difference between learning how to spell “grammar,” and misspelling it and calling out on people when you yourself can’t spell it right.
さんによる
コメントを追加
My phone is having the same problem, i lose service all the time and its in the open where i always get service. i try to reboot and it doesnt work, reset the network settings and it doesn't work, turn it on airplane mode and it doesn't work. and then sometimes it doesn't lose service for hours. what do i do?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I have bought iPhone 6plus n used for one month after that it has lost service.I tried many means n ways but still no network. But inside when I check cellular is active...
Any body help me to solve the problem....
さんによる
コメントを追加
I have exactly the same problem with CAM. i ever dropped my iPhone :- and then the problem happened.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the seame problem of "No Service"...... It has been sent to a repair center and they have said that the charger socket is damaged and so the repair is not covered by warranty...... There is no problem with charging or conecting to iTunes, is it possible for a damaged charging socket to cause "No Service"??
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Dock or "charging socket" has the antenna on the underside of this plastic piece. It is cheap and easy to replace the entire dock connector which includes mic/speaker/charging socket and the antenna. Follow repair guide for dock in upper right of this page. Please start your own question too!!!
さんによる
コメントを追加
If i was u just replace the antenna or put a foil on it that covers the battery and the signal well give it a big boost and it shouldnt be cut off anymore. That's what did and it's works good :)
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
my iphone 3g 16g just have an apple logo when i started up.. just that.. why???
what must i fixed??
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Kyle Wiens さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 48
今までの合計 40,342
