メインコンテンツにスキップ
4インチディスプレイ/カラーバリエーションは様々あり/3種のモデル/16, 32もしくは64 GB容量
331回答 すべてを表示
My iPod 5th gen will not charge
My Ipod will not charge! Yesterday it was charging just fine then later that day it suddenly would not charge. It's not the cable because I tried two different cables including one I just bought a few days ago. I also tried resetting it holding the home and power buttons but that did not work. I also tried using several different sources I tried all three of my wall chargers, I tried my laptop, my computer, my other computer, my ps3, and my ps4 but nothing I try will work! I also tried cleaning the inside of my ipod port thinking that it could just be lint and dirt in there but that didn't work either. Any other advice without me spending money would be very helpful.
Update
Ipod Touch!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
3件の回答
ベストアンサー
Hey there HardstyleZilink,
Just had the same issue. Ended up being that the pins on the dock connector were bent. Bent them back and iPod started to charge fine.
I also found out it was under warranty, so to avoid it possibly happening again I sent it back to apple and received an exchange.
You can check your warranty status here: https://selfsolve.apple.com/agreementWar...
Hope this helps buddy.
Best Regards,
Gonzalo
CleverTech
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
HardstyleZilink, since you already tried all the external options, I'd go and replace the battery. If that does not resolve it, you will have some issues with the lightning port connector. The sad part is that the connector is soldered to the logic board via the flex cable. PITA to replace if you can even find it. Try a new battery first. Use these guides to help you with working on your iPod
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
It probadly isn't any problem google says it takes 2-4 'HOURS' to charge or fully charge .
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
He solved his issue. and im sure he waited more than 5 seconds
さんによる
so if i put my ipod 5 gen. on a charger how i'll know its charging???because all i see is 3 skinny red lines inside a battery
さんによる
コメントを追加
回答を追加する
HardstyleZilink さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 19
過去 30 日: 72
今までの合計 19,220
