メインコンテンツにスキップ
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Red led is not on and not turn on
Hello, my problem is that the phone does not turn on.
I was using the phone with low battery, I tried to connect it to the socket but it did not get charge. The red led was off and the icon of battery did not change. When the indicator had 0% the phone turned off and never works again.
I replaced the usb connector multiple times after that but when I connect to the socket the red led does not appears.
After that, I charged the battery with a external charger, but the phone did not turn on.
Is the remplace of the motherboard the only solution?
Thank you!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
you could solve the problem? Please help-me!
さんによる
コメントを追加
1 件の回答
1) Check any sign of burn makes of Capacitors around PM ic - If yes : Replace them
2) Replace new PM ic and check
**BGA reworks skills required
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Victor さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 244
