メインコンテンツにスキップ
The drone is a Wi-Fi capable and it's equipped with a built-in HD camera. It is used for taking pictures and filming. Model number: PF722000
35回答 すべてを表示
Bebop drone - Camera front glass
Hello.
I have scrached the grass of the camera (bebop drone). Is there a way to change the glass? This product (EPP nose) doesn't contain glass? I mean... the glass in front of the bebop is the camera glass without any protection?
Thanks a lot
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 6
コメントを追加
5件の回答
最も参考になった回答
You can try this:
http://chtech.co.za/wordpress/parrot-beb...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Please can you contact me at harrisonashley8357@gmail.com thankyou regarding your diy lens
さんによる
コメントを追加
Check out this: https://www.youtube.com/watch?v=uyO5qx81...
I haven't tried it yet, but need too. I scratched the lens of my Bebop as well, but don't need to replace the entire camera. I hope iFixit can source the replacement lens for us: that would make life a LOT easier!!!!
- Jeff
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The result is in focus but one can clearly see the effect of the lack of anti-glare coating.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My front broke can it be replaced
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
If it’s out of focus than it’s easy fix; all you’ll need to do is to watch YouTube video.
but sometimes the camera itself is broken & if you attempt to turn on your Bebop that all it gives you is Blinking green light & nothing else.
to fix this problem all you’ll need to do is to watch another YouTube video while you remove the front Nose, remove the Camera housing, than disconnect it from the MotherBoard; Screw it back together & you’ll have a working Drone without the FVP(Camera view) but you can still fly it whiteout any problems.
All Thanks to parrot.com to have &&^&@@ us all; They manufacture Bebop Camera Replacement but for $300+ that they can go stick their heads up their ass, as I’m sure by now it’s the exact fit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
cinepallas2 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 14
今までの合計 9,309
