メインコンテンツにスキップ
Men's Fossil Speedway Watch, made of solid titanium and water resistant up to 200 meters.
4回答 すべてを表示
How can I get the back off a watch?
I need to take the back of the watch face off to replace batteries. How can I do that?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 7
コメントを追加
4件の回答
ベストアンサー
This one has a screw back so you have to use a few different special tools. Here are a few links to open the watch with each tool.
http://www.esslinger.com/howtoopenascrew...
http://www.esslinger.com/openingascrewdo...
Luckily you have different options. Good luck with your watch!
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
You actually don't need any special tools to open a screw on back. There should be special grooves on the back indicating that it's screw on instead of pop on. I use a pair of needle nose pliers ! Using the needle nose pliers straight up and down on top of the case,put the tips into the groves on either sides. Be careful to not scratch by slipping! U can use a thin peace of cloth over the back while doing this for a little protection. But that has always worked for me. Depending on how tight it's on May need quite a bit of force to break it free. I hope this helps ! Good luck ...
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Harbor Freight actually has a tool for screw-backs, cheap too...
さんによる
コメントを追加
If you have a snap-on back you can use a knife blade or razor blade[careful] to pry/lift the back off. The back normally has a slight bevel [hard to see] where you would insert the blade to pry….
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Harbor Freight also sells an inexpensive adjustable wrench for watch screw-backs, hopefully your batteries just press in and don't need other tools...
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Julia List さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 57
今までの合計 18,596
