Why won't my BRCK v1 turn on?
The device will usually not turn on, but when the device does turn on, it does not hold a charge.
If your device won't turn on or won't hold a charge, then one of two things may need two happen. You may have a faulty battery in which that part of the device will need to be replaced. Another issue may be that the connection to the battery may be bad or disconnected all together. For both of these issues, refer the BRCK v1 repair guide. Battery Replacement [無効なガイドリンク]
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 2
過去 30 日: 2
今までの合計 116
