iPhone 6 home button won't work but Touch ID does
I recently got my phone screen replaced after it got shattered. After taking t home, I checked the Touch ID which was working fine but the home button isn't working.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Could you explain this more?
Does it click in? Or do you mean it doesn't work because it doesn't click in? Or does it click in and not work?
If it doesn't click in, it's probably because they have tightened the screws a little too much under the home button, this tends to happen with aftermarket LCD's.
If the cable was damaged to the button, then Touch ID wouldn't work either.
このアンサーは役に立ちましたか?
I repaced the screen and with the home button screws just snug it seems to jam the button. Loosen them a bit and when you grab the phone at the bottom Siri comes on. What should I do?
I have a iPhone 6 Plus with same problem. I replace my screen and digitizer with "OEM" aftermarket one. The home button is clicking but doesn't work and touch ID and Reachability function which tap twice the home button work. Any idea for this?
it’s very possible you have damaged the extension cable for the home button, that sits under the shield.
I would suggest transferring over the cable from your old screen to the new one.
Hi,
I just had the same problem when replacing myself the screen of my iphone 6.
Touch ID worked well but not the Home button
I found out that the home button has, at it center, a small black round connector that you must absolutely align with the same shaped small metal connector of the metal plate that you place above the home button.
If those two aren't well aligned, it won't work.
I hope my explaination was clear
このアンサーは役に立ちましたか?
The click mechanism still works when pushing from the back side of the button with the phone open & home button bracket removed. After four attempts at aligning these better I still couldn't get the home button to click with the phone reassembled. (Touch ID still works). Any additional tips on alignment appreciated.
Hello Mr jermuy I have IPhone 6 I replaced LED screen and home bottom togather but Touch ID doesn't work I return old home bottom still doesn't work plz help me what I can do thanks
I had exactly the same problem. I find a way to fix it : recalibrate your Home Button :
1) open any app
2) long click on the power button until the power screen appears
3) release the power button
4) hold the home button until your reach the start screen
I did not restore the "click" feeling for me but now the difference between clicking and touch id is much more sensitive.
Hi,
I got the exact same issue and read several blogs with no result. Then i switched backed to my old display assembly with still the same home button. It was working fine again. The problem was the display assembly from iFixit. I have now requested an new one. Tried to switch between old and new display several times with same result.
このアンサーは役に立ちましたか?
NEVER change the Touch ID on iphone 6 because if you restore the phone without the original Touch ID you will put get error code 53.
このアンサーは役に立ちましたか?
Very true, there is no work around this one.
Error 53 no longer exists, it was patched.
Most likely they damaged the home button receiver which sometimes damages either Touch ID or back/home button function...
ive had that problem this the most likely reason!
このアンサーは役に立ちましたか?
Any result of the phone now working?
I have changed a screen today and the home button is not working as well as the finger ID isn't working either, I was very careful removing all parts and I heard if u change the home button u will get error 53 but if I change the part that you pictured will it also brick the iPhone 6?
No it will not brick, error 53 no longer exists.
1) first check all connector, reconnect all and check
2)if still not working,change flex cable,check through hard restart
3)if still not,just replace flex cable and update your iPhone through OTA update(go to setting and software update)(don't use offline firmware or restore with new version.i did same thing and result was 0,After that i used OTA update in 2 iPhone 6 and got success)
このアンサーは役に立ちましたか?
Depending on where you went for this, you should go back to the store and make sure they didn't misplaced anything close to the home button. It's probably due to bad contacts inside the phone.
このアンサーは役に立ちましたか?
They said they can look at it and replace it but will replacing it cause it to lose Touch ID?
home button damaged? A brand new white iPhone 6 home button and flex cable assembly will restore your phones menu functions if it was damaged.
このアンサーは役に立ちましたか?
This will fix home button but will lose touch ID function.
yeah, also if you update it it will most likely brick your phone. I mean it will get stuck in restore mode.
Opening the device and checking the connections to the button would be the first step. If everything is connected properly then they probably damaged the button and you are either stuck without a home button or lose touch id.
このアンサーは役に立ちましたか?
I did a DIY after water damage and my backlight is out and home button has this issue. I have no answer just jumping on the boat with this one. O Yea, and it randomly reboots every 15-20 minutes. But other than thats its doing great. I just tried loosening the screws to the home button and once it charges up I'll let you know if that helped. I am assuming the ribbon cable down by the button is the one I should be worried about and that connector? Or should I also double and triple check one of the cables that connect the screen to Logicboard?
このアンサーは役に立ちましたか?
Same problem here! Touch ID works just fine. But the home button isn't working properly.. It does click and sometimes responds, but most of the time I have to wake the phone up by the power button. Sometimes the button works well for a while, and sometimes it doesn't do anything. I've tried opening it and find the problem, but I can't find why it does not work properly.
Does anybody recognize this problem and knows a fix?
このアンサーは役に立ちましたか?
If it doesn't click at all, this is because there is no rubber on the button.
But if you can hear the click and only touch ID working, it look like the button is not connected correctly.
I spilt some water on my phone ages ago and my home button stopped working for 2 days then it worked fine and now my home button stopped working again the Touch ID still works but if I unlock it it unlocks then goes on Siri and I don’t know what to do
My phone does the same thing so i asked siri to open setting and shut siri off. Had to enable assistive touch for virtual home button on screen
IF Apple have coded the TouchID into the phone directly somehow then you either have TouchID using the original home button, or, you have Home Button use and no TouchID.
I have swapped the metal backing as well as the screen, as far as I can see there is no damage to the Home Button/TouchID assembly or the ribbon cables.
Phone has been updated as well and didn't brick.
What we need is someone that can write something that'll recode a TouchID sensor to a phone if the assembly is swapped..
このアンサーは役に立ちましたか?
I did wonder this on mine as I've seen the "nipple" move on previous iPhones, I'll take it to bits again and see if it lines up..
Right, have taken the phone to bits again and tested the "nipple" its not working still, so, next time I get another 6+ sat on my desk I'll try the screen and the backing cable off of that with the sensor/home button off of this phone and see if its the cable or the home button part itself thats borked..
Some days ago , my iPhone 6 was working very well. One day , i discovered that the Home Button is not responsibly as it was. One click - nothing. One click - it works. And so. The Touch ID was working as well. Okay, one more day and the Home Button just died. Touch ID still worked. And one more day , Home Button and Touch ID died. Wtf,really? I did nothing to my phone and it was just like magic. Boom and my home button and touch id is gone ,but why,no idea...
このアンサーは役に立ちましたか?
I had the same problem, and the flex cable was the culprit.
I didn't think the OEM cable got damaged, but picked up a new one, it didn't work, also tried a new home button, still not working.
I then tried another flex cable and was extremly carefull installing it, when I screwed the backplate back on I was carefull not to put any preassure on the cable and this time it worked :).
Seems like these flex cables are extremly fragile.
このアンサーは役に立ちましたか?
I have the same problem of the iPhone 6S home button not clicking. My only solution was to attach a iPhone 6 bracket, but this has only two screws. I have tried all the above methods and none work, the button works fine by this method but I wish I could get the proper bracket to work
このアンサーは役に立ちましたか?
Probably a dead button, if you have touch but not home button then you can either turn on the on screen home button and still use the touch sensor, or swap the home button and get home but not touch, or take it to Apple and get them to swap it and get everything as it should be..
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 18
過去 30 日: 58
今までの合計 52,069
4 件のコメント
Need more info. Is the touch ID working? Or is the home button not doing anything when you press it? Use this to troubleshoot..
Burt さんによる
how exactly is this THE MOST HELPFUL ANSWER ?
Intelligence Mechanics さんによる
Same issue here TouchID is fine, Home button isn't...
Trig0r さんによる
I had this problem and searched high and low but finally figured it out. Unplug the charging port from the board and see if the home button works. I did this and mine worked.. ended up being a dirty headphone jack
kevinbhardy さんによる
