replace the left rear door lock actuator
I need to replace the left rear door lock actuator and it makes a honking noise and does not lock the door.
petersea8 , Jim, The link below shows steps to access the lock to change, a video link and link to replacement part to give an idea of what to look for. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
http://jeepslimited.com/index.php/write-...
このアンサーは役に立ちましたか?
I looked up how to "Replace left rear door lock actuator", I tagged on the link and got this video on how to remove the door panel, problem is I had already gotten that far and then wound up putting it back on.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 14
今までの合計 3,445
