メインコンテンツにスキップ
Quadcopter with 3-axis controllable camera gimbal, 4K camera with HD wireless video system, and retractable flight arms.
7回答 すべてを表示
Can I fix my inspire after it landed in water?
I landed my DJI inspire in water can it be fixed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
最も参考になった回答
That depends on what did you do after landing on water, if you took away your battery immediately maybe not short circuit on electronic cards and of curse dry every single space inside of your drone.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I left my Inspire 1 Remote control out in the rain by accident. To my shock I discovered it the next day FULL of water. I immediately turned it upside down poured out the bucket of water it was holding thru the controls. Then took it apart and disconnected the battery that was amazingly kept sealed from the water, then "Carefully" blew out more water with compressed air without blowing the grease of gears. I did lightly regrease the obvious factory grease since I was in there. I let it sit in the Sun for a few hours, then tried blowing it out again until there was NO sign of a water droplet anywhere before connecting the battery back up. Again I was pleasantly surprised that it Turned on right away and Worked!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Drone-works.com can repair your inspire for you. All parts in stock and usually 24-48 hour turnaround
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
olihand さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 5
今までの合計 1,981
