ipad 4 is not charging or turning on
hi, i have an apple ipad 4 wifi which is not turning on or charging, i have tried different charger but its still not working, even it is not recognized by itunes
manubali811, besides different chargers you also want to try a different cable. If none of that works, consider changing the lightning connector. Use this guide for that.
このアンサーは役に立ちましたか?
hi, thanx for replying, can you tell me for what those 4 or 5 wires are there which are connected to bottom of logic board ner to home button flex??
actually while disconnecting them i accidently broked one pin(first from left side) and its track is gone so i can't solder it again
post an image of the damaged board and wiring with your question. iFixitでの質問に画像を追加する方法 Lets see what you can do to fix it.
I can't believe the walk through has 27 steps! Just to open the screen. 😂
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 244
