メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2014年に発売された、11.6インチの画面を搭載した2-in-1コンバーチブル型タッチスクリーンノートパソコンです。モデル番号は11t-n000です。
How to fix a crack screen
how to fix a crack a crack screen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
1 件の回答
without knowing the exact model and size of the screen it makes it a bit more difficult to give a better answer.
You will need to find a replacement screen, for it is pretty well impossible to fix a cracked LCD screen.
However, there are lots of youtube videos explaining how to dismantle a notebook screen to replace it with another good one.
It should be not too difficult to find a replacement part on ebay, or other places on the net. If you go to HP and search for your exact model notebook, you should be able to download the service manual for your notebook, which will have replacement part numbers for each part of the notebook. Use this part number to find a replacement LCD screen by searching the net with that part number.
Sometimes you need to first remove the screen from the lid housing, to find out how many pins the connector that connects the LCD to the motherboard has. And if you can not find a service manual, then when you have removed the LCD screen, there will be part numbers on a sticky label on the back of the screen where the above mentioned plug is, which you can use to find the correct replacement.
Some models you can remove the screen without having to dismantle the body of the notebook. You can un-clip the thin plastic housing frame that sits around the screen's edge, then unscrew the screws that are revealed when that is removed, which hold the screen to the lid.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Latoya さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 9
過去 30 日: 38
今までの合計 5,138
